P
Phill Peck
So we're u running hot water or heating
As said above, during the testing in that video I was running hot water, so it appears to be running about right. I'm just not sure how I can be using so much gas. I have the boiler on a timer cycling on/off, with an average overall of 1/3rd on and 2/3rd off, i.e. 8hrs on per 24hrs. I have now amended this.
My point was that you should do the test again for heating
Although 24kw/h is correct for hot water it SHOULD modulate down for hearing but might not be doing so
Do the test again for heating write down the start figure and the end figure after 2 minutes
Your boiler could require adjustment/ servicing
