If you have changed from a vented hot water system to a unvented hot water system then there is every chance the supplies to your toilets have changed from low pressure to mains pressure. which means if the installer hasn't changed the seatings in the float valves from low to high pressure ones, then the float valve will let by and the cistern will overflow.
Lift the lid on the toilet cistern to see if the water is at a high level, running into the overflow pipe or alternativly is there water running into the pan constantly
Hi, thanks for the help. There is no water running into the pan so probably not toilet waterflow. I also tried to switch off the main water supply and flush the toilet. So there is no water in the cistern at all. However, the noise still same as before.
The boiler and cylinder are both switched off, but the pressure is 1.5 and fill of full tank of water.
The old boiler is powermax 155x.
Will the pressure in the new cylinder causing the noise in the central heating pipes?
