pipe seals
18 Nov 2005
I bought a shower which the mixer was surface moutable for using with external pipework
it came with some rubber rings that fit around the 15mm pipework and seals it so water doesnt get through where the holes are drilled for the pipework
iv misplaced them and dont know what they are called so i can get some replacements
they were just like grommits and the rubber just seals around the pipe to water cant seep through
because of the awkward positioning of the pipes silicone isnt really an option because there is not enout room behing to get the silicone in and fsmooth properly and it just ends up lettein water through
any help would be much appriciated
i wish i knew who the manufacturer was the shower seems to be an unbranded model ih had it for a couple of years and was just doing some re sealing and general tidying in the bathroom and have lost the damn things
they were great worked a treat
they were like a washer but had an outer plastic rim and flexible rubber inside which moulded iteslf around the pipe and gave a water tight seal around the pipe
ok well assuming nobody know what these things are
are there any other tricks of the trade for seeling around a chrome pipe?
bearing in mind there isnt enough room to get a good bead of silicone round the back?
As dan said.
But useally done with silicone then fit the shrouds and nut/olive.
I will get some pics up in the morning so you gus can have a look
Hopefully you will have some better ideas than i have
Haha when i rise in the morning that is the job i have to tackle got to clean up all the old silicone and grime thats built up behind where the water has seeped through so i can get a clear picture
Ok you have fun in the morning i'll be up about midday.
Kills me these early mornings people phone up at silly O clock wanting you to clamber around in their lofts.
That is what underlings and answer machines are for.
But I have to be 35 miles away from home by 8:30 so beddy byes for me too now.
oyasumi nasai
