but many of these are sold by the glitz and glamour of a "sexy" appearance.
The functionality as an alarm system takes second place to appearance.
The more glitz and glamour that is added to the alarm system the more there is to go wrong.
Customers want gimmicks and the marketing people will provide those gimmicks as sales incentives without always explaining to the customer the adverse effect those gimmicks can have on the necessary functions of the alarm system.
Utter defensive rubbish, Bernard. In this case you were wrong with your misinformation and now you're attempting to justify it by blaming manufacturers for doing what customers ask for. May I suggest you get hold of a Dygizone before commenting on it. Yes it is a smart little controller but then why shouldn't it be if it has to be placed around a home!
There are no gimmicks, it does exactly what it is required of a PIR/security light alarm. I'm actually still waiting for there to be a separate audio tone for the second PIR on one zone and then it'll be perfect for an off the shelf, relatively inexpensive, neat and tidy, easy to use, expandable, multi programmable system.
Good, you are happy with you choice, I am happy with mine. I fully understand mine and if I wanted different tones for different zones / PIR activations then I would spend a few minutes to add it. (*) I wouldn't have to wait until market led demad persuaded the manufacturers to add it as "standard" feature.
(*) to add a different tone for when an input activated would be about 40 extra lines of microprocessor coding if it was an existing cadence with a different frequency. 60 lines if I decided to create a new cadence as well.
I get that, Bernard, but again that isn't the issue. These threads are read by many people and advice is taken away. For someone claiming to be so knowledgeable you were wrong in the advice you gave to the OP. Your response was more about yourself than it was the point in question. Alternative methods are great to read but not at the expense of inaccuracy.
