PIR????
yes but that's supposed to power the PIR's
so how you powering the pirs?
as for the sound bomb which one have you got?
I think you need to stop doing your install immediately.
Jesus .....is that the one that does not work ? Or is that a different one ? Why is it on zone 6 ? And if it is ....is zone 6 programmed to be used ?
Sound bomb is working in speaker output.
Not using the zones consecutively as the screws Heads on the unused zones are stripped so can’t undo/do up screw.
the unused zones have been programmed as unused. Should I still link them out?
i am worried for your safety.
where do the white and green wires go in 13V and 0V (where is the other end?)
The speaker terminals are wired to where?
The strobe + and -ve are wired to where?
Pir power.
The sound bomb
A strobe
well I would look at swapping your black and blue for zone 6 with black and blue for a zone you know that's working and redo the walk test.
could be zone 6 turned off if it works on one of the others that was working.
which sound bomb are you using?
I’ll have a look at the sound bomb in the morning and get back to you.
no worries just some of your earlier pictures looked strange and dodgy and the sound bombs I am thinking of shouldn't be wired to the speaker hence why i am asking which one you have.
Hi.
@secureiam previous questions:
Have swapped black and blue from zone 6 to a known working zone black and blue and redone the walk test. No difference.
Which sound bomb are you using?
Kinetic Sound Bomb KSB1.
I have checked that the zones are set as used/unused as required.
door is set as timed. Pir set to inhibit.
you say no difference, did the zone you moved to not work or did zone 6 not work?
you need to be specific.
if you swapped the zones round lets say 1 and 6, need to know how they behaved wrt to the PIR and the contact in walk test.
okay how many cores do you have in the cable 6 or 8 or......?
Have you removed the end of line resistor links on the PIR? Take the PCB out, on the rear left hand edge there may be 4 black jumper links across some of the pins. You need to remove them all if you haven't already.
