I’ve recently had an extension built, it has a pitched roof (vaulted ceiling internally) we have a 14.8 degree roof with a tile that can go down to 12.5 degrees (Marley melodie) we have gone for a 175mm x 50mm TR26 engineered timber rafter (Fully designed roof) with 150mm PIR insulation in between then rafters. We have a 15mm plasterboard on the ceiling with a 25mm tile lath. So in theory 50mm void.
we have no soffit vents and the membrane we have used is a breathable type. We have also put 100 rockwool in the eaves with a slight gap between that and the membrane.
I noticed water on the underside of the membrane earlier today... we are having plastering work done but I don’t know what could be the issue.
Any help it would be appreciated
