An existing application can't be regularised.There will be a mechanism to get the regularisation once you are the owner.
If there is a current application, with ongoing work, then the inspection regime for that work would normally be continued to completion. Regularisation is to inspect completed work, so if the work needs to be completed first then it just follows the inspection process of tbe application.Hmm - there must be a mechanism for a part built planning approved project on a building notice, that is subsequently bought and sold part way through to be formally assessed - what would it be? It sounds like the inspections on the notice haven't been requested. It also sounds like part of the build is complete and the other part not started, which may never be started, and the property might change ownership in this state. What would the mechanism be to get the existing build certified by the new owner?
Then as mentioned it's high time to ring Building Control yourself, explain the situation, whilst they may not divulge any actual information about your property (it's a contract between the homeowner and building control afterall) they will at least confirm there should have been a few inspections, that will then at least give you the ammo/some definitive knowledge to move forward.
This is not true. There are umpteen property development and refurbishment mortgage/finance products out there. The fact that the property is maybe not mortgageable on a traditional product does not mean it is not mortgageable with an alternative.without the required documentation we nor anyone will be able to purchase the property unless they are a cash buyer
Yes true.This is not true. There are umpteen property development and refurbishment mortgage/finance products out there. The fact that the property is maybe not mortgageable on a traditional product does not mean it is not mortgageable with an alternative.
However, it is the sellers problem - they are either going to have to fix the problem of uncertified/incomplete development or accept a big discount to allow someone to sort out the mess and get it certified.
As @^woody^ says.The answers are earlier in this thread.
