Apart from McBain’s brief hijack (naughty, naughty) not really; TPT & I have merely commented on misguided information.Wowee! This has gone off at a few tangents
In all honesty I can’t understand his logic. Ask him how he proposes to fill out the taper before tiling & post back. If your tile size/weight (less than around 250mm) only requires tub ready mix, then the additional adhesive depth over the taper may well give adhesion problems. If he’s using filler before tiling, I’d advise finding a new tiler! A bathroom should also use MR PB in dry areas, not standard wallboard.I asked the tiler in the end and he wants tapered edge. Taped.
Fix ever 200mm minimum.I don't want to keep asking him dumb questions, how many srews per board?
I use Knauf Aquapanel on almost all installs; it’s good value & perfectly adequate in most domestic installations unless a high output, multi jet & serous power shower is involved.I mentioned in my original post that the shower area is to be tile board. I am using Wedi. dam,n it is expensive!
Any tape will give a slightly raised surface, it won’t make the slightest bit of difference. If it helps I use 3 overlapping layers of plasterboard tape & skim/fill the mesh with addy before tiling.I do not want to use thier tape and fill system as it introduces an uneven surface for tiling.
What type of sealant is it? I wouldn’t use any form of silicone sealant; not much sticks to silicone including tile adhesive & if you spread it around too much you could have problems.I have supported all the joints with studwork and am intending to seal the joints between boards with Stixall sealant/adhesive. Any likely problems?
