Plasterboard or plaster a bathroom??
Richard you have a been a huge help, thank you..you all have.
Just one more question, my area in total is about 9m2 over 3 walls, so each wall is not massive.
I was thinking if i could get away with just the one coat i will.
To make life easier or maybe cheating i was considering sectioning the wall off vertically with beading, plastering between the beads and juts proud of them then levelling it off with a flat edge to give an even thickness, and continue to do this around the room. The problem i see here is once i have levelled off i'm going to see the top of the bead??
Or given my areas are only 3m2 is it worth sectioning it off and just go for it?
Thinking back when you guys did it for the first time, how long would it take any of you to do 3m2?
