Could do with advice on how to get the 4 walls of my lounge plastered. I'm not doing the work myself, but wanna know what to ask for, and don't want talking into something unnecessary. I want the finish to look smooth & crisp.
Annoyingly, each wall is a 'special case' - nothing's simple! The house is a small victorian worker's terraced cottage. Please help.
1. Exterior wall
This has got a bay window, and the bottom 1m has been replastered with sand & cement, I suspect following a damp course. I've hacked the lime plaster off above it - can I just butt up to this S&C plaster with new plaster, and what sort?
2. Party wall with chimney breast
This wall has still got lime plaster on. It will come off easily, but I want to put soundproof boards on this wall and then plaster them. Is there any point to hacking off the plaster first (other than gaining a couple of centimeters)?
3. Internal wall (staircase behind)
This wall's really thin and has wood within the brickwork. The bricks have been used on their edges?!
This originally had lime plaster put straight on it (which fell off pretty easily). I'm pretty sure you shouldn't plaster directly onto wood like that? What should be done instead? This is the wall I'm wondering if Dot & Dab would be better?
4. Internal stud wall
This was lath & plaster (which I've totally removed) on a stud wall. Was gonna do a simple replace with plasterboard, but wanna add some soundproofing, somehow. What would give me good results without being too expensive? I'm gonna replace the wall on the other side of the framework later, if that makes a difference.[/b]
5. The ceiling
Someone's took the plaster off the ceiling but left the lath, and nailed boards over the top, skimmed and finished it with textured paint(!). You can see each board's edges (as if they're convex) and it looks megashit. Can this be skimmed over?
1. Exterior wall
5. The ceiling
