adam2 said:Thats reassuring John.
I was just wondering will the guy have to devill the bonding coat when its dried or can he apply plaster straight on...The browning was already devilled previously when we scraped off plaster as we found it. I'm sure he knows but i won't be there when he does it.....
adam2 said:The browning had already been keyed heavily. The bonding undercoat was placed on this. The plaster was then applied on top.
Have just seen the room today. Most of it was done in the morning and cracking usually appeared within 30 minutes if not earlier before.
Well on first impressions there are no cracks. The finish is smooth and very level/straight. It looks like a professional job but will wait to judge on that.
Near the window sills (the sides) where the plaster meets the window frame he spoke about wood or strip....not sure what he was talking about I think he means we should place new wood strip(vertical) to level finish off at this intersection..a bit confused what he means?
The main problem was the suction..very dry wall needing lots of water. he ended up using a sweeping brush to appply PVA and water.
He will start 2nd room in the morning.
"JohnD" of the way you explained anout patching, i know of many plasterers who have done this and the finish coat "fixes" the suction problem but one year later some patches can start to crack !JohnD said:I'm no plasterer but can do patching and chases.
When I had an old house plastered (mostly back to brick) the guys put on a thick backing coat (bonding or browning depending on the wall) which was devilled and cracked a bit as it dried, then came back the next day and put on a very thin layer of sirapite which they flicked with water and polished very smooth when it seemed dry. The cracks in the backing coat did not come through.
Isn't that usual?
(I will add that it's a pleasure to watch an experienced pro, both for speed and the startlingly flat and smooth surface)
