Installing cable runs on walls that are to be plastered.
Is it against regs or is it just bad practice to leave cables either uncapped or not run in conduit etc. Basically just clipped to the wall(or not even clipped) and then plastered over.
Reason I ask is I've spent some time this week stripping plaster from walls before a Kitchen refit and found numerous cables running horizontally, vertically and at all sorts of angles. Been close to knicking the cables a few times
Had the new kitchen units being going straight in then its more than likely that a cable or two would have been drilled through.
