Running approx. 12 metres of hot and cold 15mm PE-X plastic pipe from a CT75 pump to a shower, is it necessary to fit plastic pipe inserts when using plastic connectors as it isn't mentioned in any of the pump instructions. I'm also a little concerned about reducing the bore and the effect that this will have on flow rates
