Good afternoon all, this is my first post here, and im looking for some advice on a consumer unit for a garage. I will explain the best i possibly can, and was advised my a local domestic electrician of what i require but wanted to double check he was telling me the easiest way to install this as i will be doing the donkey work and getting him to do the final connections.
dont mean to be under mining him, as hes a friend of mine, but i know times are hard for a lot of people and dont want to carry out work which is not required.
here goes.
i have a 12 way consumer unit in the house, which has a spare way for a mcb(no rcd protection), (sector fusebox and mcb).
At some stage a 4mm t+e cable has been buried under the ground and taken to the garage , im guessing ready for electrics to be taken into the garage which was unfinished when i brought the property.
I now want to have installed 5 double sockets, for tumble dryer,washing machine, spares for lawnmower,strimmer, and a drill etc from time to time. what size MCB would these need to be on and would they need rcd protecting? also are these best installed in a ring main? approx length of garage is 8 metres from where consumer unit will be to last socket?
2 strip lights , what size MCB? and will these need rcd protection? and 1 outside security light?, 2 way switch.
next question is, what size mcb would i be required to add to exsisting consumer unit in house in order to supply the feed to consumer unit in garage?
seen a few consumer units for a garage but am confused weather i need one with a 63a 30ma dp rcd or a 40a 30ma dp rcd?
i look forward to your help, and i know this post may seem confusing, but i allways get a second opinion on advice ive been given and compare them to make sure im not being ripped off.
sorry to my good friend who i know is on here, who has given me advice but after losing a lot of money due to wrongfull advice by companies in the past i have taken your advice and asked for advice to back up your quote
here goes.
