Please help me to silence my intercom!
Yes try that, fitting the above switch requires you to solder to it's pins.
A switch with screw terminals may be better however I do not know of a micro toggle switch that has screw terminals.
The next option may be to buy one that has short wires connected to it, you can put the wire from terminal 6 into a chock block connection to one of the wires and the other wire into terminal 6.
Fit it just like the previous discussion about fitting a switch.
Hi matty, thank you. I’m in rented so not too confident to be doing any fittings. If I unscrew terminal 6, can I just leave it like that and then screw it back in to get it working again? Cheers again
Just bear in mind that it will no longer work - at all.
So any deliveries, mailman etc. you will not know.
Thanks guys, did it tonight and it works! Also able to put the screw back in if need be.
Generally we know if people are coming so not an issue - but keeping in mind for deliveries, we happen to have something arriving Saturday so I’ll put it back in for that.
