Hello
I have just upgraded our semi gravity to a somewhat kind of working y plan system but i am having some problems which i think is to do with where the pump is situated.
Setup is a potterton kingfisher 2 boiler with 1 x flow and 2 x returns(1 from hot water cylinder and one from rads). I left the pump where it is which is on the return from the rads. I installed a 3 port valve. The vent is on the flow prior to the 3 port valve and the feed is on the return from the cylinder.
The problem i am having now is that when just HW is on the flow goes up vent pipe and into the header tank.
I attach pictures to help explain a bit better.
In order to remedy this as i think the pump is in the wrong place, should i fit a pump just before the valve?
Also are the vent a feed pipe connections in the wrong place, if fitting a pump to the flow then maybe i could connect the vent and feed pipe prior to the pump and maybe on the old connection to the rads?
FLow and return from cylinder is all 28mm which is a right in the you know where.
Anyways here are the pictures and i would appreciate any replies/advice on my situation.
Thank you ever so much!
