Plinth Heaters
17 Nov 2005
Manchester
We are getting quotes for a new kitchen and are thinking of replacing the 2 small 500 rads in the kitchen/Dining room for 1 plynth heater connected to the central heating system.
The floor space in the room is 14metre squared
Will these type of heaters warm a room that size and are they reliable?
If they are what size should I be looking to buy?
Are these heaters a good idea?
Do thet have to be connected to the leki for the fan?
Thanks,
Con1_uk.
They are a good heater, but they make a slight noise due to the fan, which can be annoying.
Yes, they have an electric motor to drive the fan. When it is turned off (or not working) they give out little heat.
They will make the cupboards above rather warm.
(p.s. they will go wrong more often than an ordinary radiator)
Assuming you mean 14 sq metres, not 14M x 14M, then I use a 2kw rad in mine, which is ample. There are tables for radiator calculation which require to know size of internal/external walls; insulation; size and type of windows; solid or suspended foor; what is above/below/next to the room. Some kind person may point you at a website.
The Hydronic models just connect to the heating system, Electric models can be used where there are no easy pipe routes available and the Duo models combine the two.
quote="con1_uk"]We are getting quotes for a new kitchen and are thinking of replacing the 2 small 500 rads in the kitchen/Dining room for 1 plynth heater connected to the central heating system.
The only plinth heaters that I have fitted are indeed connected to the central heating system because they are mini radiators??
If it's any help, we use the Smiths Environmental range (called Space Saver) because they seem to be a bit better made than the other lot (M+++N) and have a 5yr warranty. See www.smiths-env.com.
We recommend the Space saver to customers with solid tiled floors because it really takes the chill off the tiles, the warm airflow being so low down.
If you have dogs or cats, they need to be cleaned regularly. The heater, I mean.
Thanks for the info
Is there anywhere else sells these heaters please?
Thanks. :D
