8amp fuses are not available
Yes they are.
Yes they are.
Note the word "any" in BS1362
“The rated current may be any value not exceeding 13A. For use in plugs, the preferred rated currents are 3 A and 13 A."
Place I worked at the computers in the offices would regularly go down because the girls all bought 3kw fan heaters in and plugged them into the same circuit as the computers, which got to be too much for the 32 breaker they were all on.
I’m glad you asked. You need to provide a link to this alleged Post Office fuse policy. without any provenance this alleged story is just fairy tales or more of your deranged imaginings.Where? A link would be useful.
I believe the Post Office (as it was then) downgraded 13 amp plugs to 8 amps for this reason.
Never heard of that for the 22 years I worked for them and we had many a 3KW heater. I should have known as my duties included PAT.
I can confirm that in GPO sites the 13 amp plugs were down rated a maximum of 2 kW loads.
Where the load was to be greater than 2 kW special dispensation had to be obtained or the equipment to be installed had to be modified so as to have it's internal loads shared between two power supply units.
Non of the radio paging equipment we installed took anything like 2 kW so the restriction did not cause us any problem. Type approval just needed to show the maximum load could not exceed the limit That included during prolonged fault conditions.
Here's a 7A example.
https://uk.rs-online.com/web/p/cartridge-fuses/0412582/
