Plug in RCD
29 Mar 2005
Hello All,
Just a quick one,
I was wandering can you get a plug in RCD (rcbo), just replaced my sisters old shower, it wasnt RCD protected, just a 30A plug in circuit breaker, the old push button ones.
Cheers All
simple answer: you cant. and RCD needs both live and neutral. a fuse only has live. youll have to either get a new CU or get a mini shower CU
or fit a seperate rcd after the CU in its own box
as to why its not practical to make a RCBO for a wylex standard (plug in) consumer unit
have you seen the size of a rcbo?
have you seen the size of a plug in wylex breaker?
not to menation the wiring arrangements would be a nightmare for such a device especially given the general cramedness of those CUs
30A - that's a tiny shower. Shame you didn't go the mini shower CU route so that you could have upgraded the circuit to support a bigger one..
Further to this post,
I have installed this shower, all i have to do is fit the RCD when it arrives tommorow, its the shower enclosure type incorporating an MCB.
When i have fitted shower cable to RCD next to CU, i then have to wire from RCD to CU, which is straightforward, but what about the useless 30amp fuse that is in CU at moment???
1: Do i have to install further 45Amp fuse?
2: Or (crossed my mind) have 6mm link wire?
Either feed it from a suitable fuse in the carrier in the CU, or via henley blocks in the meter tails.
It's not useless, it is protecting the cable that runs between the main CU and the shower CU.
That depends on what size cable the shower circuit is wired with, and what the rating of the shower is.
Not on a 45A breaker.
