I'm currently building a deck out of the standard softwood decking boards you can get anywhere.
1/. When screwing nails into the deck boards, should I drill a pilot hole first?
2/. Can you use a plug maker for the fascia boards. I am using a deck board as a fascia, I have seen joiners use plug makers when they fit skirting boards to hide the screw heads?
Thank you.
Thank you.
