The Intergas is 13 litre per min. But, the DHW temperature can be set to 65C by the user. Too hot for taps. But, have a blending valve set to 45-50C supplying all the taps except the two showers. What this means is that the hotter the water to the mixer the more cold water will be needed to get the required 42-45C mixed at the shower valve. Thermostatic mixer valves as essential.
You may want to fit wondervalves at the kitchen sink outlets with a 6 litre cartridge in each. On the basins have a lower litres cartridges like 4 litres. Then when these taps are turn on they will reduce influence on the shower(s), by not stealing pressure and flow. And also reduce water usage reducing bills.
