Plumbing for an electric shower
24 May 2013
Hi there,
I have an electric shower and looking to do the plumbing side of it myself if I can.
Am I ok to run the water supply 'Td' off from the cold water supply for the bath tap, and run the pipework under the bath, and up the wall (the shower will be opposite ends to the taps)
Is there anything else I need to be aware of? and what sort of pipe/connections should I be using?
Its a triton 9.5kw shower.
I could drop it from the loft, however we will eventually be replacing the boiler and loosing the tanks in the loft etc.
Cheers
Simon
As long as it is mains pressure to the bath then that's fine to take the supply from there. Connections depend on existing pipe size but compression tee would be ok.
Cheers Denso - I assume its mains pressure - its certainly powerful!! Anyway to double check?
Turn it on and try to stop it with your thumb.
If it is fairly easy to stop chances are it's tank fed, i.e. not suitable.
If water squirts everywhere chances are it's mains fed, therefore suitable.
Copper, plastic, your choice. Are any joins, elbows etc going to be visible?
No joins visible if it goes to plan, under bath and chase out the wall to then plaster over and tile eventually. Cheers.
