I want to put in a 500mm tall larder unit in a space with odd water pipes. It does fit without moving the water pipes and I have a switch cut off button would it be ok to do this with a 10cm gap between the side of the unit and the half wall next to it . Or could a plumber change it so it could go against the wall
