Maybe that's the point.As I've said elsewhere, the BS7671 definition of "installation" is so vague and all-encompassing as to be totally useless. Anything from a switch+lampholder+bit of cable to a highly complex industrial electrical 'set-up' would satisfy that definition!
Maybe the perceived "vagueness" is actually the flexibility people need to organise the totality of their electrical stuff into a meaningful and manageable number of "installations"?
You, for example, would have fewer problems (none??) if you had multiple installations instead of one.
"An assembly of associated electrical equipment having co-ordinated characteristics to fulfil specific purposes". So if you have such an assembly to fulfil the specific purpose of providing electrical power to (for the purposes of argument) Ground and First Floors, would that not be an installation?
Imagine your situation writ a bit larger. You have a big detached house, and in the grounds you have a separate workshop, a swimming pool and poolhouse and a bungalow for granny. Somewhere a 3-phase supply enters your demesne and gets split into a single-phase for the house, a single-phase for the workshop, a single-phase for the pool and poolhouse and a single-phase for the granny house.
What characteristics are there of either the phase going to the workshop, or any of the protective devices or final circuits within it, which are co-ordinated with those going to and in the main house to fulfil a specific purpose? You've already agreed that the independence of such separate parts is such that neither is affected by the other, and the presence of the other could not be detected in either, so what kind of co-ordination is going on?
This is getting surreal.I suppose I would agree that "a block of flats" has one installation - but I'm also inclined to think that each of the flats within the block has its own separate installation.
Either it has one installation or it does not.
Either each flat has its own separate installation or they each have a fragment of one.
