I am connecting a new radiator to my CH heating system using polyplumb pipes and fittings. (the rest of the system uses the same)
I made one connection just to make sure i could do it properly - what I found is that when I made a connection with 22mm pipe it was very rigid and had no pull back, but when I made a connection with 15mm pipe it easily rotates in the joint and also can pull out very slightly (about 1mm - maybe not even that much) and can be pushed back in.
Is this normal for the 15mm pipe or is this just a bad joint??
