Hi
I have a very poor flow coming from my hot and cold taps on my indirect gravity fed system. (Bungalow)
The tank is located in the loft space and can be raised some more but only by about 3 ft, will doing this greatly improve my flow rate?
The hot and cold to the bath are both fed by 22mm pipes, with 15mm pipes branching off to the other taps, the route of the pipework is fairly direct with the minimal of bends.
If raising the tank doesnt work is their anything else i should consider?
Thanks in advance
Thanks in advance
