Apologies if this has been answered elsewhere - I didn;t find it in my searches.
I've just installed a thermostatic shower for a friend, and am inevitably having trouble.
There is very poor flow. They previously had two Mira showers which worked acceptably well, so it's strange that this one doesn't !
Setup is:
Hot water cylinder system, 1st floor en-suite with the hot water tank backing onto the on-suite. Hot water feed from tank, cold water feed from a tank in the loft (previous shower installation instructions specified that this must be the case).
I've put a gauge on the cold water pipe and it didn't register. I've swapped the shower unit for one in another house that I know works well - no change. The shower that I installed at my friend's works fine in the other house.
I've flushed out the pipes, so I'm confident there is no crud in the way. Filters are clear.
My friend doesn't want to to have a pump, but is happy to buy another shower so long as it will work.
I'm considering feeding the cold in from the main rather than the loft tank, will that help at all?
I'm guessing I need:
- suggestions as to thermostatic/mixer showers that work well with low pressure/flow
- suggestions as to how best improve the poor flow
Many thanks in advance!!
Setup is:
