Having just read snb's post, and having missed your earlier statement about the Synergy valve specification, I wouldn't bother unless you're going to be adding a pump.Thanks Softis - sounds like moving the hot supply is the way to go.
It's not cryptic - they're both commonly available products.I've no idea what an Essex flange is, or how to demount whatever Hep2o is ! Any chance of a layman's translation for this numpty?
Well, it's in the wrong place, but putting it in the right place is pointless without a pump, because you won't reach the 0.5 bar minimum that the valve requires.Are you saying there is no point in moving the point of hot water supply?
You're going to have to tell them that they have the wrong valve for gravity supplies.If I suggest changing to a shower costing another couple of hundred quid you'll understand I need confidence first.
