I bought a pop up waste, and rather than call out a plumber, I thought I'd have a go at installing it myself.
The current setup is a plug on a chain, with the bog standard overflow and stopper you get on cheap plastic baths in new houses.
I have removed the Pipe in order to get to the metal plug stopper from underneath, and unscrewed the one screw holding it in place from the top.
However, the metal plug stopper is stuck to the bath!
Have I missed anything? Or is it just stuck down with silicone? I don't want to prise it off if it's attached any other way.
I am also having difficulty removing the overflow and mechanics-how is that normally fixed on?
Thanking you in advance,
Rave
Rave
