porch Roof
5 Sep 2006
Staffordshire
Hi All
My brother and his mate have nearly built me a porch and i have to do the roof work.
I want it to slope upto the house from the front of the porch then i want to carry it on all across my front window.
I have done a diagram of the side view but without the wall at the side please could someone have a look and tell me is that correct before i go ahead
Sorry if picture is too big
ManyThanks
Andy[code:1][/code:1]
spot on.
the brick work needn't go that high. we tend to leave the external brick work down a course or two and this allows you to lay the soffitte board on to the top of the brickwork (saves scribing).
you then "wedge" it down with some sprockets fixed to the rafter ends.
we also use joist hangers on the ceiling joist-to-wall plate connection.
p.s. the wall plate needs to be 75mm lower as to allow the ceiling joists to sit on top of the plate.
HI Mate
The external brick work is 1 brick lower than that shown, i can leave that as it is then,i was goin to put another row on like the picture but it makes a lot of sense what your saying.
Not sure what you meen about wedge sorry.
thats what i thought about the ceiling joist by using joist hangers.
Which part do you meen about the 75mm lower part
Thanks for your reply
Andy
by wedge i simply mean a piece of timber nailed to the side of the rafter that is pressed down onto the topside of the soffit trapping it down onto the bricks.
all it does is stop the wind from flapping the soffit about. ;)
in the diagram you show the wall plate at the same height as the ceiling joists, with the actual joist notched on to it.
this is wrong as it will take too much "meat" out of the joist.
you need to fix the wall plate lower so that the ceiling joist sits on top.
the wall plate is usually still visible even after you have fixed the ceiling plaster boards.
The ceiling joists should sit on the wallplate bedded on the new blockwork - the way you have shown it would require the joist to be notched to half its depth!
The rafters should be birdsmouthed onto the wallplate (ie lower them by 25mm), and the ceiling joists nailed to the rafters to restrain them.
The top wall bearing plate (on the house) should be lowered too - to reduce the notch in the rafter
to simplify your diagram, rather than call all three "wall plates", you should actually say:
pole plate (bottom left)
pitching plate (top left)
wall plate (bottom right)
