Porgrammable Room Thermostat
Right, the Dil switch is set to pumped and not gravity. The wires are as follows:
Neutral: Black
Live: Red
1 (HW Off): Red ok
2 (CH Off): (Blank) ok
3 (HW On): Yellow ok
4 (CH On): Blue this goes to your new stat
the blue wire from 4 (ch on) goes to "com" on new stat, the "on" connection from stat goes to brown on the hsa3.
The original wiring of the programmer was correct, all you had to do was put the new stat in series with the 3 port actuator (hsa3) so from 4 in prog to "com" in stat then "on" in stat to brown on 3 port valve, so put the wiring back as it was and wire the stat as shown.
edit forget the colours, all the cables are "live" at one time or another
