I don't think you'll capture enough energy from the woodburner with that setup to make much difference to the comfort of the otherwise unheated rooms. I might be wrong- if I am you may run into bother with localised kettling (giving steam pockets in the top of the loops reducing flow thus more kettling until there's a massive gurgling whoosh as the steam (energy) escapes up the expansion pipe.
One plan I contemplated with mine was ducting the warm air from around the woodburner to the rest of the house- trouble is I'd left it a bit late to create duct runs to the rooms so didn't actually try it.
You'll lose some of your precious energy heating the oil boiler with that setup (you could avoid that by closing the iso valves on the oil boiler), more importantly when you do run the oil boiler you'll lose an absolute shedload of energy warming the woodburner plus quite likely inadequate circulation in more remote radiators. Fitting isolation valves to that homebrew hex would be a very very bad idea.
If you are capable of soldering up a homebrew hex as the picture you'd be more than able to plumb in a thermal store, a wet woodburner and associated bits and bobs (loading valve being the main one).
Having considered everyones input to my project , I think I will leave it this year , but next year I will consider puttinging in a thermal heat store , then some solar panels and also the back boiler.
So next move is to try and get a backboiler for my Stovax, Stockton 11 woodburner which sits in a large inglenook.
