Potentially, a sprinkler or mist system and a Grade C, LD2 alarm system and no corridors, but fire doors on habitable rooms off the landing.we are talking building corridors or 1st floor means of escape plus sprinklers.
I'm not overly informed on these matters, but from the way you've marketed your house, 2 beds and a loft/storage room, what is the issue? The stairs instead of a loft ladder?
If I were to build some stairs to my loft (totally unconverted) would I have the same issues? Can't you just make it more "loft like"?
For the situation you describe, is not just a case of removing stairs, and some fittings. The loft would need to be deconverted back to almost it's previous state - so that it's not easy to re-convert it once the front door is closed.So is having stairs making it habitable? If not, could you make it not habitable? remove carpet, remove a radiator........ then you have just a loft with stairs...... the new owner can then chose to connect the rad and add a carpet....
Right - sounds like the OP is in a world of pain then. Saying that, when we were house hunting a couple of years back, there were a few with "storage areas" for lofts that clearly were habitable but could not be classed as such - but then I suppose BC weren't involved.For the situation you describe, is not just a case of removing stairs, and some fittings. The loft would need to be deconverted back to almost it's previous state - so that it's not easy to re-convert it once the front door is closed.
A section 36 enforcement notice cannot be served on you after the expiration of 12 months from the date of completion of the building work. A local authority also cannot take enforcement action under section 36 if the work which you have carried out is in accordance with your full plans application which the authority approved or failed to reject.
https://www.planningportal.co.uk/info/200128/building_control/38/building_regulations/3
