Hi all,
First time posting so forgive me if all technicalities are not quite right.
We have recently moved into a house and have just completed renovating our kitchen. The kitchen was originally much smaller and was extended in the late 80's. Previously to this rest of the back of the house was extended and then a few years later the kitchen extended to the same extent.
The house is multilevel and the kitchen is on one side of the hose with vaulted ceiling. We have insulated with clotted between and under the rafters and all was fine until the recent cold weather. We now have damp patches on the joint of the sloping ceiling and the external wall, however this is only in the part of the kitchen that was formed out of the extension.
I was fairly confident that it is not water leaking in (although there are signs of rotten felt at the soffits. The membrane is a traditional non-breathable felt but I was sure to leave a 50mm gap between the membrane and the insulation and also maintained a vapour control layer when installing the insulation.
On closer inspection (and I should have checked at the start but made an assumption) the roof space of the extended part of the kitchen does not meet up with the loft space as there is essentially what would have formed the exterior wall of the first extension before the kitchen was extended. Having looked closer in the loft, the wall is sealed right up to the ridge line essentially making the kitchen roof space its own system.
We have soffit vents but I am thinking that without a vent at the top of the roof or lack of loft space with air bricks there is no passage for air to circulate and therefore warm air is becoming trapped and then condensing.
Yesterday i pushed back 4 or 5 roof tiles at the eaves where the damp issue is and there was clear signs of water running down the outside face of the insulation boards.
I had a roofer round to look tonight to price up installing a tile vent towards the top of the roof space and his opinion was that it is a broken tile allowing water in, but he was happy to install a vent if that is what I wanted. I explained that I did not think it was a leek as we had large amounts of rain 3-4 weeks ago and no sign of water ingress, it was as soon as the temperature dropped that the problem started to show. Also if it were a leak and it did somehow make it through the felt there would only be water drops on the insulation between 2 rafters, not between all the rafters unless it was more than one leak. The part of the kitchen that is in the original house construction shows no issues but this does have free ventilation into the loft.
The other option to installing a roof vent is to core drill some 100mm holes through the wall thus joining the kitchen roof space with the loft - any thoughts on how successful this would be?
I was just after some advice as to whether my logic is correct as I am now doubting myself so I hope someone can impart some knowledge.
Thanks,
Rob
Thanks,
Rob
