Poterton PTT2 cylinder thermostat
26 Nov 2006
My Cylinder thermostat is intermittently clicking on and off (rapidly), it stops if I adjust the temp' setting.
How can I prove whether the thermostat or the thermocouple is faulty - or is the above enough to prove that the thermostat is faulty as I suspect?
Thanks,
Chris.
kchris said:
...is the above enough to prove that the thermostat is faulty as I suspect?
Yes. The hysteresis on a non-faulty cylinder stat is too much for it to operate in the rapid way that you describe.
