Can anyone help?
I have a fully pumped system using 2 honeywell V4043H valves. Valves, timer, pump and tanks upstairs. Boiler and thermostat downstairs. Central heating and hot water can work together or independently.
My potterton netaheat electronic 10-16 boiler gives no heat. There is no light in the inspection window. My Grunfos pump was jammed, I freed it up and its working normally. My Randall 4033 timer doesn't tick but when I set heating or water to overide the pump and boiler start up. The boiler makes its usual running noise but doesn't light and remains cold even after hours of running. Can hear water running through boiler and its fan working.
When I turn the honeywell T6360b room thermostat down to below room temperature the stat clicks and the boiler goes off. When I turn stat up above room temperature it clicks and the boiler comes on but gives no heat and stays cold.
Prior to the boiler not heating when the themostat wast turned down my radiators stayed at the same temperature.
Thanks in advance for your assistance
Steve
Steve
