potterton diverter valve assembly
21 Mar 2010
Can anyone help, diverter valve assembly was leaking, brought new complete valve and changed yesterday. I had both CH and hot water, changed valves and now led flashing saying blocked condensate pipe or low pressure. Push up the micro switch on diverter manifold and boiler fires up, let it off and led flashes. Can anyone help
It's trapped air.
Bleed the pump and open the auto air vent screw on its rear end. SHould be left open but often weeps if you do.
Turn the gas off, and lift that microswitch and it'll shove the air out.
Potterton have mane a lot of different boilers and they mostly have different diverters.
You have not told us which one you have! Are you Irish or something?
not irish, i thought the name would have explained everything? anyway thanks and its sorted
