potterton EP2001
I thought the Tempus range lit when a button was pressed, it seems I was mistaken.
The LP saves you pressing a button once to change from gmt to bst, and it comes with the time set (running the battery down) out of the box, which saves a few seconds setting the time, once. Setting the program on the LP takes far longer though.
The other Tempus useful features are all missing though, the LP is still just SO last century !
rovert47 said:
corgiman said:
rovert47 said:
gazthepottertonengineer said:
just fit an EP2002 or EP3002 as its straight swap and will only take 1 minute max ;)
What even a layman with all those wires?
er yes as the ep2002 fits on the same back plate, no wiring needed
Brill,thanks,where can i get one from please?
Bought one fitted it,thanks for the help,if it hadn't been for this msg board i would of ended up paying an electrician an arm and a leg to fit me a new one. :D
sorry to piggy back on this thread
I have one of theses units and need to take it off the wall but cat fathom out how to get the thing off
Any advice guys?
thanks
Andy :?: :?:
Dont piggy back a year old post as no one will answer you (sept me o course)
when you have a question start a new topic
anyhoo look under the programmer and on the right hand side you will see a half inch long hole, with the sparks OFF!!!!!! pop a screwdriver into here push gently the pull the bottom away
