- Joined
- 23 Nov 2023
- Messages
- 2
- Reaction score
- 0
- Country
I have a Potterton Heatmax combi 28 HE that goes through short 5 sec cycles of the burner being lit then shutting off when using DHW. The CH works fine. The DHW is being tested with a single hot tap (not a mixer). The short spurts of burning is just enough to produce luke warm water. I understand a clogged plate heat exchanger is a common cause of this problem but in my case these on/off cycles start whilst the DHW heat and other sensors are still cold. There are no error codes. I've tried a new DHW NTC sensor. I'm suspecting an electronics fault, would like to be sure before buying new PCB.
Any advice appreciated.
