potterton kingfisher boiling intermittently
This is a semi-gravity system IIRC. No m/vlvs.
Yes, but it could have been turned into a C Plan
The boiler will fire with no pump if you select h/w on the programmer. There is no boiler interlock on gravity hot water.
So it carrys on heating up until the boiler thermostat or overheat stat turns it off.
Yes, but that will make no difference to the problem.
but...
If the pump has stopped but the boiler continues running, the fault is in the HW circuit or the boiler.
Thats not true on a Gravity system.
Paul.
1. Yes, but that will make no difference to the problem.
So it carries on heating up until the boiler thermostat or overheat stat turns it off.
but...
2. That's not true on a Gravity system.
1. The problem is that the system is sometimes "boiling" when it is on HW only. This means that the control system is not turning the boiler off. The main controls are the boiler thermostat and the overheat thermostat. If there is a C plan, the cylinder thermostat is also involved.
2. What's not true, the first quote or the second?
