- Joined
- 15 Jul 2006
- Messages
- 10
- Reaction score
- 0
- Country
The fault is now fixed. In fact it was 2 unrelated faults, which is why the combination of them appeared so puzzling. Having changed the sequence and modulating boards without any luck, I also changed the distribution board. This removed the fault whereby the high flame light came on without any combustion. However the fan was still not rotating, and consequently no ignition sequence. Checking the DHW limit thermostat revealed an open circuit at the plug that goes onto the distribution board. However the fault was not the stat, but the crimp between the lead and the terminal in the plug. It seems that it was not crimped very well and when I pulled the plug out of the board when I first started the fault finding exercise, the last bit of continuity broke which gave rise to the open circuit. Repairing the terminal with a soldering iron fixed the problem and DHW and CH are now working perfectly.
To answer a couple of questions that were asked earlier, I wanted the circuit diagrams to try and find why the high flame light was on with no combustion. With the information in the manual it is difficult to trace the fault path, but with a proper circuit diagram it would have been quite easy. And secondly I am located in Essex.
Thanks to all who have replied with constructive suggestions, they have been much appreciated.
PP
PP
