Hi this is my first post and I would appreciate some advice on a problem I am currently having with the above boiler.
The Potterton netaheat 10-16 boiler sparks up and ignites the pilot when the hot water selector on control box (seperate) is switched on. The boiler however, will not fire up - there's a good pilot flame and the mercury sensor is well within this flame. The relay is new and the fan works well - no blockage etc.
The room thermostat is broken so the boiler won't fire when only the central heating control is used. Could this T-stat/control box be the source of my problem with the boiler firing up even when only the hot water selector is used.
Tried Corgi and would rather buy new combi than spend on gas valve etc. Could it be a simple wiring problem: pump or diverter valve etc???l
