doitall said:But didn't the others have a permanent pilot
Sat in my hotel room thinking, wish I had the book
This is around 1980.bripl said:only the balanced flued ones had a permenant pilot all the fan assisted had electronic ign ithink the early ones with the vapour switch
This one is around 1980, definately elec ign, comes one either when the room thermo tells it to or hot water come on to heat up. all electrics seem to work ok, its just that the thing does not seem to want to light!¬ (except for pilot!)bripl said:only the balanced flued ones had a permenant pilot all the fan assisted had electronic ign ithink the early ones with the vapour switch
simonoxford said:How much would a replacement boiler be....any idea?
Thanks for this. To be honest, i move house in less than a week so just want to get it fixed/replaced the most econimical route. Had someone round today who just seemed to guess at which parts needed so the bill could run into ££££'s. his final say was the Gas Valve but then if i give him the go ahead to get it, it's non refundable. He did try two other parts that he then took back and got his money back so i'm no worse off but just alot colder!bripl said:depends on too much without seeing would not comment ideal replacemet would be a profile straight swop but others will tellyou to have the sys flushed [good practice] part l requirements and of course you would use a corgi reg installer to comply with regs some would say adays work others would disagree do a search for the spareparts got to be better as this is a good boiler compared to the current models available
many thanks. is this for the gas valve?bripl said:try keep the heat on part no103299 the part is 388-060 which replaces 402801 cost is 72.50 plus vat tel 08700133946 same day dispatch b4 3pm
