Potterton Netaheat 10/ 16
8 Nov 2006
London
Dear All
I have a wall mounted Potterton Netaheat Electronic boiler which sits in the garage Turned on hw & ch in the evening, worked fine. Some hours later went to kitchen - was greeted with a loud pitched humming from boiler. But boiler not functioning. Switched it off, left it for some time, switched back on - same noise but no sign of life. Tried again a few hours later same problem, then again, same problem. Whilts I appreciate this type of boiler is a widow maker and sits in the garage now wheer near any living space please advise what problem could be? Many thanks.
Hi Fitz1
Fan seems OK as it spins by hand but buzzing noise appears to be from main PCB area where relay, thermostat, air pressure switch etc are located!!!
Fitz forgot to tell you that that is a positive pressure case boiler and the cover should only be removed by a competent CORGI.
The buzzing could be anything but you should be able to listen. Sometimes a short length of hose pipe helps to listen to a small location.
Tony
The pcb as you call it is pretty unreliable on these. Put one end of a screwdriver to it and the other end to your ear. This will let you know if it is this buzzing.
Hi All
Just to let you know I had a CORGI Registered engineer change the Fan for £150 and all is well.
As I am not CORGI I would not even consider touching any boiler let alone this one!!!
Many thanks to you all
Hi All
You already have!
Opening the combustion chamber cover should not be done on any boiler by a non-CORGI.
However, on your model and a few others, its particularly dangerous as if the case seals leak then carbon monoxide can leak out from the boiler.
Tony
