Hi. I have an intermittent problem with the above boiler, only it is getting worst.
My system is fully pumped y-plan. Pump is ok.
When the boiler is switched on, the fan starts up and after a few seconds, the pilot lights. The problem is that the main burner will not light. It doesn't come on and then go out, it does not light.
The fan remains on and so does the pilot. I think you can hear a faint clicking noise, sounds like a an ignition spark, but that is all.
The boiler will remain in this state for hours if not turned off.
Usually you can get it to work by turning it off and back on, but it is getting harder to get the main burner to light.
Any help greatly appreciated.
Paul
Paul
