hi guys, i'm getting slightly concerned about the situation i've found myself in so i thought it was time to try and figure this out. id like to mention that i have pretty much no idea what im talking about in regards to this, i've never had an issue with this kind of thing before and as such am feeling pretty useless. its basically resulted in me living at my girlfriends house due to the temperature at mine.
the boiler i have is downstairs, mounted to the wall in my kitchen and it is a potterton netaheat electronic 10-16. the programmer thing is a british gas UP1L. we have a cylinder in the airing cupboard which is upstairs. there are 3 radiators downstairs and 3 upstairs. we do not have a thermostat other than the one on the boiler so cannot control the heat of individual rooms.
i have a few questions to ask first:
how should this system work? should i be able to turn on the central heating without the hot water being on as well? currently if i turn the central heating on using the bg controls, absolutely nothing happens, no noises, no ignition, no heat.
however if i turn the hot water on, the pilot light ignites, makes the noises that i assume are normal and then if i turn the ch on i can hear the water start to flow and my radiators heat up.
now i assume you need hot water in the cylinder for the radiators to heat up so this kind of makes sense, but this is coming at an extortionate cost (we're on a gas card/meter) and whilst the radiators are getting hot, the house is simply not warming up.
it also seems like the boiler is cutting out quite regularly?
any advice or knowledge would be gratefully recieved.
mark.
mark.
