Potterton Netaheat
Chrisr, extremely glad to hear that you will be offering no further “advice” on this subject as I do not appreciate being spoken to in that manor. You obviously think you are way above the rest of the people on this forum so maybe you should just call it a day, then you could give someone who is more helpful a chance to comment.
pixey
I have been following this topic with interest (i am not a plumber or heating engineer)
Pixey, every one is trying to say that what you want to do can be done (with the right "bits") but, with out seeing it to tell you to "do xyz" could be wrong in your case. There are some occasions where you have to call in a profesional, and this is one of them.
a little knowledge is a dangerous thing.
There is no point in you and ChrisR "slagging each other off" as it achieves nothing. You will just have to face facts, you will have to call some one in to give their advice, you are not going to get the answer you want on these forums, there are some things that should not be done as D.I.Y. and this is one of them.
now let us end it here.
I've been in engineering all me life, me old man was a plumber, blah de blah, I'll rewire a house to the c/u, wack in another rad, but f++k about with a boiler ? NO WAY ! (but I'd love to learn, am I to old at 45?) A bomb waiting to go off,. There are times you have to admit defeat and get a pro in.
By the way, Chris R going from a previous thread, if you need a Corgi man to connect your gas cooker, why did they make them "plug-in" bayonets? ( Technically I broke the law !!)
P.S. Still partying masona!!
Scoby_Beasley, is this what you are looking for?
(it is omo but in a differnt box, made by unilever)
Scoby - sorry if i mislead. Anyone can use the bayonet connectors on cookers, just the copper/iron pipework has to be corgied. Almost without exception, built-in hobs have to be piped in rather than using flexies.
Having said that, an awful lot of cooker bayonet females do leak when the hose is disconnected. There's a newer micropoint style which is a bit better. Btw All gas fittings can be seen on bes.ltd.uk., which is a hugely useful supplier of most plumbing stuff.
Scoby -absolutely not too old at 45. There's nothing hard in it, mostly water, gravity, and air, then what happens if things get pressurised, , whether by accident or on purpose.
If you looked through a couple of collegy (ie NVQ2) textbooks, and looked in some catalogues to see what bits are available, you could start earning(slowly) very soon. I'd say that to anyone who's practical, bright and interested to learn, with a bit of respect for regulations which are there for good reason.
Once you're calling yourself "a plumber" you can do the Corgi thing which currently takes about 2 weeks and £1500 or so.
The hard bit comes with apparently simple things where there's stuff you didn't know you needed to know about. Recent posting illustrate, but take even a tap washer - you find you can't isolate the tap. It could be from a combi, the mains or a tank. You might consider freezing IF there's access. Turn a gate valve and it might come away in your hand, or not close, or not reopen. You might get a difficult air lock in the pipes if you drain down. You might have to work in dirty dark unboarded eaves to get to something. If it's council property everything might be locked, or shared with others. Plenty more along that road. Then you get the tap apart ( you may not be able to, even with a puller to get the handle off) to find that cos its been leaking for ages (13 years in a tap I had recently) the brass seat has eroded away. You try to recut it but it's too far gone. You can go buy plastic insets - but then there's hardly any flow at the tap when it's open - which you don't find until you've spent however long clearing that air lock. And the customer then notices that the gland seal also leaks so wants that done - sometimes not possible so they want a new tap - which may mean rebuilding a bathroom practically from scratch.
I must be partying tooo much, I'm seeing double now !!! :LOL: :LOL: :LOL:
