Potterton -Performa 24 - Keeps coming on - Micro-Switch Prob
www.partsarena.com/baxi
You will find the drawings and part numbers here , they are on the plumbcentre graphics as i ordered one the other week picture is away from the diff valve .
Might be in the wiring harness section
Thank you gas112!
I've found it:
BAXI Part Number: 248207
http://www.partsarena.com/baxi/
Catalog » Potterton » Boiler » Performa » Performa 24 (GC No. 4739306) » Parts List » Performa 24 » WIRING HARNESSES
Item: 372 on the drawing:
372 248207 E66484 Cable - Selector Switch/Pump
BAXI Manufacturers Product Code: 248207
(Baxi Combi 248207 Microswitch & Cable Assembly)
and you can get it on eBay:
http://www.ebay.co.uk/itm/Baxi-Comb..._Plumbing_MJ&hash=item2ebc98102c#ht_500wt_949
Regards.
Thank you gas112!
I've found it:
Regards.
Replaced the DHW Switch and the Boiler is working fine now!!!
Many Thanks for all your inputs!
I had EXACTLY the same problem as Charlie567 - my boiler was coming on then switching off on its own accord.
I read the posts of Agile and ChrisR who also included a very helpful link to the Performa parts diagram, opened up the boiler and had a look at the switch.
It was indeed corroded and looked like it had been damaged by a previously leaking DHW valve which I had replaced last year.
The wiring looked complicated but not impossible so I went out and bought the new part Baxi 248207 and then carefully replaced each wire in its correct place.
I switched the power back on and could not believe it when the bolier fired up and turned off as normal.
A huge thankyou to both of you for explaining the problem and also giving me the confidence to go ahead with the repair. It's well within the ability of a good DIY'er.
Job done for sixteen quid!
Because so much of the wiring has to be replaced I dont generally advise that as a DIY job.
It would be much easier to just change the switch using a choc block but we are not really meant to do that!
Tony
