Hello all,
I have a big issue with a Potterton Performa 28, there is a light flashing above the 50 sign, this says its a flue/fan issue.
I after doing some intel on forums including this one I came to the conclusion it was a new PCB that ws required.
I purchased a new PCB and fitted, first time I powered up it seemed to work ok but as soon as the Rad temp Guage got to 50, all lights went out and then returned to the original issue again i.e flashing above the 50 sign. I then reset and seemed to start up ok i.e the fan kicked in and could hear ignite showing a light in the flame light(LED) this then went straight out and should a Flame fault light.
now everytime I turn off then on or reset I get the original issue whereby the 50 light flashes again.
so to be clear, not heating and no hot water in taps, only a error on the 50 light that apparently means fan/flue fault.
Guys please help what should I do next?
kind regards
G
kind regards
G
