Apologies if this is all history now. I just joined DIYnot and have not figured out how the threads work or how old they are.
I have a Prima 60F, fan cycles as described above. The fault is the APS (pressure switch) which has open circuit NO contacts on the microswitch. The diaphram and switch assembly all comes as one part - v. expensive. Easy to remove and refit though. Fingers crossed...I'll befitting the replacement tonight.
